Salta al contenuto principale
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 Domande Visualizza tutte
Why did my Xbox 360 S turn off by itself?
Hello, my Xbox 360 Slim just turned off randomly. It didn't respond to the power button getting pressed. So I unplugged the power supply from the Xbox, after it booted up just fine but after 30 seconds it did the same thing again. (I heard a beep before it turned off.)
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Sounds like it may be overheating. Have you cleaned the interior any? There may be a build up of dust causing it to overheat and shut off because it can’t cool the Xbox properly. Try opening it and seeing how much dust is in it, and if there is a lot take a brush and clean it out, and see if the issue persists. Hope this helps!
Punteggio 0
1 Commento:
It's not overheating, I had it on for 3 minutes then while it was loading it beeped and turned off.
da
Aggiungi la tua risposta
Kur Yente sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 158
