Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
ear phone no sound, everything else is working
Hi!
I had water in, but could open all and dry it out with rice. Everything is working fine now, only the ear speaker doesn't (earphones and room speaker work perfectly).
I tried to clean out the earphone jack as it was explained in youtube, but no effect. Is it possible that one of the cables 1, 2 or 3 is responsible for the ear speaker? Could I have replugged them badly?
Thanks for all answers!
Markus
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
you need to reopen the iPhone and check all the cables to make sure that none of them got unplugged, if they did, that could explain a lot of your problems, even if 1 cable is unplugged it could be your problem, even if its at the bottom of the iPhone
Punteggio 0
Thanks!
Yes, indeed! It was cable 3 (the small one below cable 1) which is difficult to plug.
But I replugged it and now everything is working!
Great website, guys!!
Markus
Punteggio 0
Aggiungi la tua risposta
markus sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,958
