Salta al contenuto principale
Informazioni sulla riparazione e sullo smontaggio per la versione aggiornata del 2020 del MacBook Air. Lanciato a marzo 2020.
103 Domande Visualizza tutte
Unable to boot to recovery, internet recovery, or bootable recovery
Hey everyone.
I lost my passcode and recovery key and was trying to boot into recovery.
I’ve tried Command + R: the bar slowly filled up to 100% and then just remained there.
I tried Command + Option + R and Command + Option + Shift + R: it got the globe icon, asked me for my wifi credentials, but once it started loading the bar started glitching (like getting full, then having empty spaces in the middle). Eventually I got error -2003F
Bootable recovery media: same as Cmd + R, slowly filled up to 100% and got stuck.
Some more info to narrow down the issue:
- With internet recovery I can see the Macbook using 1mbps download for about 30 mins then it stops
- It boots to the typical login screen just fine, but I’ve lost my passcode and recovery key
I recently did some repair work on the computer. Particularly, the battery was giving me an issue so I removed it (it is without a battery till my replacement arrives). I also was having issues with the microphone, but I damaged the replacement part so the microphone and audio board are also disconnected. Could this affect it?
Thank you!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Turns out it was the battery. Re-installing the battery fixed the issue.
Punteggio 0
Aggiungi la tua risposta
Nathaniel Dsouza sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 86
