Salta al contenuto principale
Rilasciato il 20 settembre, lo smartphone più grande e costoso di Apple del 2019 è dotato di un display OLED da 6,5", un sistema a tripla fotocamera e un'autonomia della batteria notevolmente migliorata. Successore dell'iPhone XS Max.
iPhone 11 Pro Max apple logo loop.
The back of my iPhone broke badly and it began to do the apple logo loop so then I restore it and it came back on but again it started doing the apple logo loop. Would the problem be that the back glass broke and maybe it broke the wireless charging pad? Or what could be the problem
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione prescelta
There are multiple issues that can cause this. I would suspect a faulty part. Since you have Brocken the back glass I would recommend sourcing another housing for your logic board. If you wish to keep that housing the parts that can be causing your issues are:
·         Battery.
·         Charge port.
·         Screen.
·         Front flex assembly.
·         Front or rear camera.
In some rare instances a hard drop can also cause the NAND or CPU to be compromised which would end up in a costly repair.
Punteggio 1
I had the same problem with my 11 after replacing the back and the battery it seemed to boot fine
Punteggio 0
Aggiungi la tua risposta
Steve Carrasco sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 9
Tutti i Tempi: 799
