Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Domande Visualizza tutte
Replaced display, but home button is physically stuck
I recently purchased and installed a new display for an iPhone 3gs. Was able to install it with no problems and it worked great. But after about a week my home button became stuck. Took it a part, checked for anything that might be causing it to stick but there isn't anything wrong that i can see. It's usuable, barely, I have to press rather hard. The home button feels depressed, but it doesn't "pop" back up.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hello,
Some possible solutions:
1) The home button is not lined up within the frame. The home button has little wings coming off both sides, that need to sit into grooves.
2) If that isn't the problem, then the home button itself is damaged. It is a mechanical switch, and the actuator on the back of the home button is likely damaged.
Hope this helps,
Xico Solutions
Punteggio 0
Risposta Più Utile
Also there is a silver metal plate beneath the Home Button Flex Pad, that must be present and centered below the Pad. If plate is not in correct position, Home Button is very unreliable.
Punteggio 1
Aggiungi la tua risposta
Reyrtyu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,138
