Salta al contenuto principale
80GB vs 120GB Speed Difference
Hi,
I like many here have an original MacBook Air (A1237) in which the hard drive has tanked. I have opened the computer and found that the hard drive inside is a Samsung HS082HB/A; 4.2k, PATA, ZIF. Looked on this site and many have replaced it with a 120GB version; Samsung HS12YHA. When I look online the 80GB drive is getting hard to find new. The only issue I have having is that it seems the HS12YHA is a 3.6k RPM drive. Seek and Latency seems about the same, just a tad slower.
My question is has anyone felt there was a difference in speed? iFixit sells what appears to be a 4200 RPM used 120GB HD; also wondering if this is truly 4.2k?
Thanks,
Jhan
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The iFixit one is truly a 4.2K RPM. The difference between the 3.6 & 4.2 is about 15%, slightly above the negligible range. The only real time you will see a real difference in performance is if you are using a lot of virtual memory - having lots of programs open etc... If you are a power user or use programs that require a lot of memory the 4.2 is the one to have - to keep you from drumming your fingers as much. The 3.6 is fine for normal users.
Punteggio 1
2 Commenti:
Yep I'm a power user. Thanks for the info, will go with the one from iFixit. Just wished it was new. Apple has told me to replace the 80gb it's $101; drive is new. Plus a $40 install fee and no they won't sell you just the drive.
da
140... not bad for apple... lol
da
Aggiungi la tua risposta
Jhan Jensen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,637
