Salta al contenuto principale
Full capacity smartphone released on AT&T, with 4G LTE connectivity.
The phone won’t charge
i attached the image of what exactly i think is causing the phone not to charge, but im not 100% sure if that’s the problem. had this phone for YEARS so im sure there might be other things wrong. what can i do to fix this?!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
That definitely shouldn’t be bent like that, I suppose you can Try very carefully bending it back in place with a very small tool as a solution and see if that works, other than that, completely replacing that connector entirely may be possible, though it is directly connected to the mainboard.
Punteggio 0
Aggiungi la tua risposta
Julie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 61
