Power light blink 2 times
My Samsung tv won't turn on, the power led blink twice, I did open the tv and notice the following
- The back light does go full, dim then off. If I keep the power on, it keep going on the same cycle
- If I disconnect the main board, the backlight stays full the entire time.
- Did replace the main board, and the behavior is still the same.
I do have access to multimeter, any ideas what to do next?
Btw, model number is UN55RU730DF
Update
When I do disconnect any one one of wide cable that comes from main board to screen panel, I can hear sound and use remote, no image/video
Thanks
Questa è una buona domanda?
I’m having the exact same issues
Did you find out what’s wrong with it??
da Aaron H
I have the same issue! But originally my mainboard didn’t have sound so replaced it and now the TV behaves this exact same way. Thinking about replacing the psu as my TV broke after a series of rapid outages but still unsure of pulling the trigger on that.
da Alexis
I have the same issue on a q70T 75” Samsung. Just had a tech out for the first time. He literally plugged it in watched it try to turn on and blink the red light twice. He said the panel is bad. Then proceeded to fight with my wife (because I was at work) and that we needed to pay him for diagnosis and that we had to pay for the part and installation over $1000. Luckily I keep all my emails receipts etc. so he ate his words. Now they have to order a panel wait for it then come install the panel.
da Patrick Prorok
Has anyone found a solution to this? I have the exact same problem with my 58" samsung TV model UN58TU7000F. I am thinking about replacing the main board and power supply but I would like to know if anyone figured it out first.
da Cameron Craig
It is LCD Panel issue. Need replace LCD Panel
da D MAX_
Mostra altri 2 commenti
