Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
Battery keep maintenance message
Hi there,
I replaced my battery and used icopy to keep sn.
when I plug in 3utools
3utools show 100% ok.
But in setting iphone x keep the message maintenance and if i click show 77% same percent old baterry
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Changing the serial number to the original one will have no effect. You also need to transfer the flex assembly from the original battery as that is where the chip is that is linked to the phone. You need special equipment for this procedure like a micro spot welder and micro soldering iron.
Punteggio 2
6 Commenti:
But its just happens with X?
coz another one like 8 plus / xs / 7 I use icopy and works well.
da
@diogotm From the X up. I don’t see how it would have worked on the XS. There are videos on YouTube showing the procedure.
da
@diogotm Well there’s your problem. They just replaced the battery without copying the serial number over.
da
That’s make sense, if you copy serial to show 100% in 3utool you can’t change the percent health in iPhone settings
But if you DONT use icopy you have 100% health in iPhone setting. BUT if you plug iPhone in 3utools they show the red message “the battery my be replacement”
OMG apple apple
If I like the both 3utools 100% and iPhone setting health 100%
I need to swap a microchip, right?
Thank you very much your patience and your answers
da
Mostra 1 altro commento
Punteggio 0
Aggiungi la tua risposta
Diogo Thomaz de Melo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 204
