Salta al contenuto principale
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
I just replaced the screen and doesnt work
Hello, I just replaced my screen and digitizer of my Ipad 6th Gen. But now only some parts of the screen are working. Is there a fix for this or send my screen back for another one.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Hello Tyson,
In this model, the digitizer is an independent system. Unfortunately, it is led with quite long tapes with a non-grounded signal. During installation, remember that the tape circuits provided for earthing must be glued through the conductive layer in designated places. Otherwise, it causes uncontrolled short circuits to ground or the signal does not reach the motherboard at all. Another (indirect) reason is too strong bending of the connection tapes and, as a result, breaking the continuity or being trapped by the screen.
You'll have to unfold it again and check your work. Alternatively, you can use an experienced repair shop.
Punteggio 0
2 Commenti:
I don’t understand the “earthing” cable part
da
Bob - it mens "grounded" :) (slang)
da
Aggiungi la tua risposta
Tyson Hall sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 111
