Salta al contenuto principale
Lanciato nell'aprile 2010 / processore Core i5 2,4 o 2,53 GHz o Core i7 2,66 GHz
590 Domande Visualizza tutte
Where is the position of the CPU/GPU from the outside.
Hi,
I want to build a water-cooling notebook stand for my MacBook and for this purpose I need to know where the position of the CPU and GPU is from the outside.
Perfectly would be a picture from the bottom of the Unibody with a mark where those components are positioned.
I found some pictures on ifixit.com but this is not what i needed.
Thank you very much,
Jonathan.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi Jonathan, I am unable to provide a photo as of now, and you have probably already found the answer yourself. I can tell you however that they are positioned between the left side of the keyboard (around the hight of the TAB key) and the letter Y on your keyboard. Hope that helps.
-Lui
Punteggio 2
Aggiungi la tua risposta
Jonathan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,234
