Salta al contenuto principale
The Xiaomi Poco M3 is a budget smartphone which was released in November, 2020 and is equipped with a big 6000 mAh battery block, a tripple main camera and a 6.53 inch IPS LCD.
26 Domande Visualizza tutte
Why my phone cant open/on after update and reboot
after update and reboot my phone still not on the screen
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Risposta Più Utile
Apparently it was a little problem for me but to be honest it happened to me after unlocking the bootloader and wanting to install a custom rom.
I could not install any return to the normal version of xiomi
and everything is normal until one day I restart it, I felt it very slow and it did not turn on like 20 min and one day I turned it off and it did not turn on what I did was remove the battery for 20 min and download the same OTA THAT I HAD FLSHED WITH THE XIAOMI TOOL AND THE PROBLEM WAS SOLVED
Punteggio 2
Can you feel any vibration, if no the update may have corrupt the operating system. Before you try rolling back the update long press the power button for about 20seconds. If this does not fix it you will need to contact Xioami support
Punteggio 0
Punteggio 0
Aggiungi la tua risposta
mr usop sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 990
