Salta al contenuto principale
Repair guides and technical knowledge for the Xiaomi Mi Mix 2, released in 2017.
14 Domande Visualizza tutte
How can I check whether my charging port is broken? (Xiaomi Mi Mix 2)
Hello there!
I have a problem with my current Xiaomi Mi Mix 2. I does not charge. I suspect that the charging port is the cause of the problem since I have had problems with it before.
My question is how can I check whether the charging port is really broken or if the problem is somewhere else.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The easiest way would be to buy a little USB Amp/Volt Meter and plug it into the wall and then your charger cable into that and it will let you know if the charger is drawing amps or not. If not it’s most likely in need of being replaced.
The meters are less than £5 if you look around…
Punteggio 1
Aggiungi la tua risposta
BugReport Plon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 225
