Salta al contenuto principale
Processore Core Solo da 1,5, Core Duo da 1,66 o 1,83, oppure Core 2 Duo da 1,83 o 2 GHz. Questo copre i primi modelli di Mac mini basati su Intel dall'inizio del 2006 alla metà del 2007.
PRAM Battery Not Working
A Mac Mini I have wasn’t saving the date and time/wifi so I ordered a new PRAM battery. I put it in but the date and time/wifi still isn’t being saved. I flipped it around but the same issue occurred. I have pushed the metal fingers as close to the battery as I can, yet it still wiggles a little bit, so maybe that’s why? I tried it on another A1176 I have and the same problem.
Questa è una buona domanda?
Punteggio 0
5 Commenti:
What is the batter markings?
It sounds like you either got the wrong one or its bad
da Condividi
@danj I bought the ones that were in the guide
da Condividi
@Jordan Baron - What is the batteries markings?
da Condividi
@danj Energizer CR2032
da Condividi
@Jordan Baron - Well, that's the correct battery, why I pressed was there is a thinner battery which is only 1.5v.
Your comment "yet it still wiggles a little bit" made me question if that was your issue. At this point your logic board socket maybe damaged as the battery is firmly held.
da Condividi
Aggiungi un commento
1 Risposta
Before you return what sounds like a bad battery, open up the date and time preferences and make sure you have the “set date and time automatically” checked.
Punteggio 0
Aggiungi la tua risposta
Jordan Baron sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 9
Tutti i Tempi: 421
