Salta al contenuto principale
Hi, I am unable to power on
Unable to power on my laptop,even after battery removal
Questa è una buona domanda?
Punteggio 2
2 Commenti:
What happened before it wasn't turning on? did it power off suddenly or after the battery drained?
da
i had the same problem - i could not power on, and had difficulty powering off completely. the power button was flashing slowly along with the caps lock key - the screen was pulsating gently at the same rate. when the mains power was plugged in it would power down completely if i held the power button down, but would not power up.
any way - i loosened all the screws and took off the bottom to see what i could see - and that fixed it!! so i gave it a small clean and pressed one or two things in place in case it was a poor connection - it is now running again.
da
Aggiungi un commento
1 Risposta
Hey Wow,
Are there any indicators when you plug in in to AC power?
Do any lights show up?
Punteggio 0
Aggiungi la tua risposta
WoWsOmE ViN sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 353
