Salta al contenuto principale
Repair guides and support for wired or wireless devices that provide internet connectivity.
status and wlan blinking continuously
So I have a D-link wireless router DI-524 and for some problem the status and wlan parts of the router seem to keep blinking/ flashing continuously and i cant seem to connect directly to the internet with the blue cable. I have to use another internet cable instead.
Questa è una buona domanda?
Punteggio 0
6 Commenti
Jordan, can you please explain a little more about the "another internet cable instead."
Status LED – a blinking light indicates that the DI-524 is functioning properly. WLAN LED – a solid light indicates that the wireless
segment is ready. This LED blinks during wireless data transmission. Have you tried a reset of your router?
da
the regular cable you would normally use
blue cable is the one from modem to router
yes held it for 15 secs
da
So what other cable do you have to use to connect? How do you have it hooked up? Is your router working if you connect a cable to your computer?
da
So what other cable do you have to use to connect? I can use the blue cable that is connected from my modem to the router or i can connect a regular grey cable from router to computer.How do you have it hooked up? modem to router to computer basically.Is your router working if you connect a cable to your computer?yes what i usually do to get internet.
da
So it is your wireless that is not working?
da
Mostra 1 altro commento
Aggiungi un commento
1 Risposta
Soluzione Prescelta
somehow i solved the problem. thanks for all the help
Punteggio 0
1 Commento:
How did you?
da
Aggiungi la tua risposta
Jordan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 18,962
