Intermittently quits when pushed forward
Machine quits when pushed forward, starts when pulled back again.
Questa è una buona domanda?
Sounds like an electrical problem, most likely the power cord is broken inside the insulation, try simply moving the cord back and forth right where it meets the vacuum and see if you experience the same issue, if you do you need to replace or repair the power cord.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 35
