Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
Hold switch not working after replacment
Hi
I have just replaced the volume and hold buttons on an ipod touch 4th gen. The old ones worked, but I snapped the thin cable when working on it so had to replace it. Now the volume buttons work, but the hold switch will not. I have checked the solders and they're fine. I think the replacement may be defective, because I cannot think of anything else. If anyone has any suggestions I would love to hear them as I do not want to wait three weeks for another hold switch.
thanks alot
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
If the solder is fine. Did you check for small tears in the cable?
Make sure there are no solder bridges or loose components near the solder area. If all is well you will likely have to order a new one
Punteggio 1
Aggiungi la tua risposta
matt prior sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 641
