Salta al contenuto principale
The Buick LaCrosse is a large/mid-size luxury car manufactured and marketed by Buick since 2004. The LaCrosse is now in its third generation, slotted above the Buick Regal as the brand's flagship.
20 Domande Visualizza tutte
erratic instrument cluster most days
every few days,my instrument cluster is erratic..gauges will all go down then back up,including voltage and signal lights won’t work..sometimes when I push the off utton,the car doesn’t shut off 2014 buick lacrosse..what could be the problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
loose wiring, broken wire or water in electrics most probably, does the cluster and lights stop working whilst your driving? have you checked the battery terminals are secured tightly and there’s no dirt or discharge on them?
Punteggio 0
Aggiungi la tua risposta
Tina Baker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 84
