Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
How to replace buzzer?
hello, how to replace buzzer in 3gs? can i must use the soldering iron? any instruction please
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
iPhone 3GS Vibrator Replacement
There's the guide from here :) no soldering needed, just need to take the screen assembly off, un-screw the logic board / disconnect cables from it and remove that, then it's just a couple of screws to remove the current vibrator.
If it doesn't seem damaged, you can try and bend the pins up towards the logic board again, it may have just come out of contact with the bottom of the board.
Hope it helps.
Punteggio 2
2 Commenti:
sometimes it's the mute switch causing problem..it's only a tiny switch. Does iphone recognise that mute/vibrate is switching on but you have no vibrate, or does nothing happen when you flip the switch?
da
Good point, check what pollytintop advises as well! :)
da
Aggiungi la tua risposta
wysoki sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 794
