Salta al contenuto principale
Philips Wake-Up Light Alarm Clock with Colored Sunrise Simulation, 5 Natural Sounds & Radio. Released in April 2017. Model number: HF3520/60.
device "clicking" quickly like proximity sensor feels something
Philips HF3520/01 Wake-Up Light - suddenly starts making never-ending quick “clicking“ sounds, speeding up.. This is normally sound of proximity (touch) sensor.. but there is nothing close to device, and it is clean…. It is unstoppable, only it stops if disconnected from power… After connecting it can work for hours correctly, but problem appears later again…
Questa è una buona domanda?
Punteggio 2
1 Commento:
Same problem. Mine will work for weeks before this starts again, but the only fix is to unplug for at least a few minutes - The longer the better it seems. Works fine and I still love it otherwise.
da
Aggiungi un commento
1 Risposta
Mine has the very same issue, is there any known fix for this infinite phantom clicks? I really like my wakeup light for years now, it still looks like on day one.
Punteggio 0
2 Commenti:
I solved it. you just need to solder the wires well
da
So you think it's a broken solder joint? Is it enough to heat the PCB? I am highly unskilled when it comes to microelectronics.
da
Aggiungi la tua risposta
guglmobil sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 32
Tutti i Tempi: 442
