Salta al contenuto principale
Modello metà 2010, A1278 / processore Core Duo 2,4 o 2,66 GHz
795 Domande Visualizza tutte
Slot de memória em curto
Hi, My name is Carlos. I’m from Brazil
I have a Mid 2010 13” MacBook Pro A1278. Memory Slot 0 (next to the motherboard), must be in trouble. When I put a SO-DIMM stick in it, the equipment turns on and does not upload video. When I put the SO-DIMM in slot 1 everything is normal.
How to replace the defective slot?
I will be grateful for someone to send a step by step.
Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Sadly if the memory slot is bad there is little you can do other than replacing the logic board.
Let’s give this a try first! Carefully loosen one quarter turn the four screws which hold the memory socket frame.
Make sure you are using the correct SO-DIMM RAM - 204-pin PC3-8500 (1066 MHz) DDR3 SO-DIMM
And keep in mind this system is limited to 8GB using two 4GB SO-DIMM’s
Punteggio 0
Aggiungi la tua risposta
universidadedelphi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 31
