Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
Cannot install macOS because of "missing firmware partition" issue
Hi all,
i have this 2015 retina macbook pro that i used to use until the ssd failed. I just use it on my desk now,
anyway, i tried to install macOS Big Sur but it gave me a message, “you may not install to this volume because the computer is missing a firmware partition”. I’ve learned that macOS High Sierra and newer don’t work, but macOS Sierra and older work. It’s so annoying and once or twice it worked but other times it doesn’t. Internet recovery only gave El Capitan.
I also have a 2009 macbook pro with Catalina if that could help with the formatting to APFS if that is the issue.
I am also running Sierra.
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I have had this same problem a couple of times before and I found the solution is to 1st Update the system to High Sierra as that will include the missing firmware update. After High Sierra is installed and all the updates are done you can then update to newer systems.
Punteggio 0
Aggiungi la tua risposta
ryoseo1020 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 126
