Salta al contenuto principale
The Dyson V8 Absolute can be identified by its model number: 214730-01. It’s a cord-free, hassle-free vacuum released in April 2016. The Dyson V8 Absolute comes with HEPA filtration and up to 40 minutes of the most powerful suction.
Wand won’t click
The wand button doesn’t click when you insert it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Are you inserting the vacuum into the wand or the wand into the head that runs on the floor?
Did you look inside where it should be inserted to see if there is something small in the way of getting a tight fit?
Punteggio 0
Thanks for your email.
It happens when inserting the wand into the vacuum.
I did check for something in the way but it was clear.
It is like the spring in the release button of the wand at times not strong enough to make the release button click.
Any help on this would be appreciated.
Doug
Punteggio 0
Aggiungi la tua risposta
Douglas Gateman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 574
