Salta al contenuto principale
Lanciato il 3 marzo 2017, Nintendo Switch è un dispositivo palmare che può essere usato con la TV o in movimento.
PowerA controller not pairing
Hi, I had to send my joycons to get fixed (drift much) and I had a PowerA enhanced wireless controller connected and paired to the switch so I kept on using it and had no problem even without the joycons. Until I decided to try and connect it to my PC and to do so I unpaired from the switch, now I'm trying to connect back to the switch and it does not pair! Has anyone seen this before? Do I need the joycons to pair it back? I'm using the touch controls in the change grip order to pair it with no luck, I already followed the steps correctly. What am I doing wrong?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Trying the “find controllers” feature could work to connect them, or maybe if the controller has a sync button try that. I don’t know if you have the power-A controller that uses batteries or has the usb-c port, but if it can run with a wire try that maybe. I hope that helps somewhat
Punteggio 0
2 Commenti:
I have the one with batteries, no wire connection possible. I tried the sync button and the lights in controller indicate it is in syncing mode but it never comes up in the switch in the change order/grip screen! Thanks for the answer though ?
da
I guess find controllers is your best bet, since you didn't mention that you tried that. If the switch remembers a controller, and you hold on it in the menu, as long as the controller is nearby and has battery power it is forced to connect. I had this same issue on my pro controller a while back
da
Aggiungi la tua risposta
Felipe Akira sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,952
