Salta al contenuto principale
Il Town & Country è stato riprogettato per l'anno modello 2001, utilizzando la piattaforma Chrysler RS e inizialmente disponibile solo in versione a passo lungo (LWB).
I can't find my cabin air filter, in 2006 town and country
i can’t find my cabin air filter under the passenger dash 2006 town and country LX
Update (04/01/2021)
I can’t find my cabin air filter in my 2006 chrysler town and country LX. It’s not under the passenger side dash, neither behind the glove box
Questa è una buona domanda?
Punteggio 4
1 Commento
I canot find cabint air filtter for a/cin town and country 2006
da
Aggiungi un commento
5 Risposte
Risposta più utile
Hi,
According to the 2nd video Locate cabin air filter in this link there is only a cabin filter if you have the automatic climate control feature.
Punteggio 1
in the passenger side under the dash between the center and glove box you will see a long black 2" x 8" with a nob the center turn to unluck
Punteggio 0
Not all chryslers have a filter I know unbelievable huh it can only be one of 2 places behind the glove box or underneath the glove box the one underneath is very long and a pain to reinstall if youu don't hv a filter and your cars air smells from your air conditioner being turned on my suggestion is to get a can of lysol and spray some into the air conditioner intake located on the outside of the vehicle at the bottom of the windshield and see if that helps
Punteggio 0
there is no hvac filter
Punteggio 0
Under the dashboard next to the instrument panel is a black plastic panel with a slide lock. It’s not very easy to spot because you have to get down low and look up…but it’s there. It’s about one and a half inches wide and several inches long. Pull the slide lock towards the back of the vehicle and then pull the panel down. The slide lock pulls out very easily. It was not easy to spot. I looked and looked and almost gave up when I finally saw it.
Punteggio 0
Aggiungi la tua risposta
vernellsmith07 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 78
Tutti i Tempi: 5,120
