MacBook Air Will not turn on
Last night I changed the thermal compound on the cpu and Now it wont boot or turn on
Questa è una buona domanda?
a few things you cant try.
open it back up and check the screw holes and make sure there arent any marks on the opposite side of the holes. ( IE long screw in short screw hole and it hit a PCB component. ( Hopefully its not this ))
check your connections \ ribbons \ plugs, makes sure everything is seated properly. inspect the pins and contacts on ribbons and plugs you removed.
does it power up at all with it plugged in to power?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 58
Yea It broke. CPU died
da Graham Denney
