Salta al contenuto principale
The PSP 3000 was released in the U.S. on the 15th of October 2008.
Why is my psp not reading UMD discs?
My PSP is not reading my UMD discs. Please help.
Update (03/26/2021)
It doesn't spin at all. Yes it boots ups. No errors. The discs looks clean. Nothing jammed. Under worked before. It is updated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
when you put the disc in does it spin up?
if not you may have a tough time.
does it atleast boot up?
does the PSP give any errors?
inspect the disc and see if its dirty.
check to make sure nothing is jammed in the slot of the PSP itself.
is this a UMD that worked before and just doesnt now? or is it a new game?
when was the last time the firmware was updated?
Update (03/26/2021)
so if thats the case there are 2 versions. you need to figure out which one you have. the psp 300x or xc.
both tear down guides are on this site along with the drive needed to be replaced.
X= PSP 300x UMD Drive Replacement
XC = PSP 300xc UMD Drive Replacement
good luck my friend!
Immagine PSP 300x UMD Drive
Guida
Difficoltà:
Facile
15 minutes
Immagine PSP 300xc UMD Drive
Guida
Difficoltà:
Moderato
Punteggio 0
Aggiungi la tua risposta
Joamir Terrero sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 2,335
