Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Can water get trapped under the screen resulting in an odd white stain
I was cleaning my iPhone 5, I used an old toothbrush to get gunk out of the small crevices. I also used electronic wipes near the silent mode switch. I powered the device back on, and when it was booting up I saw a large white stain on the corner of the device. It slowly disappeared after a few days, but it’s still somewhat there. Is this water? Is it permanent? How can I fix it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
im pretty sure if its caught between the glass in the LCD you might be out of luck. can u take a picture of it?
i would go into this expecting to have to replace the screen but one thing that i would try is trying to get some alcohol in there. use the highest percentage you can find though. 90+% id say 99 if you can get your hands on it. let it soak through and then air it out for a couple of hours ATLEAST and then try to power it up and see how it looks before completely reassemble.
Punteggio 1
2 Commenti:
Can I use hydrogen peroxide?
da
i wouldnt. that stuff would probably cause alot of bubbles and what not to be trapped. alcohol is your best bet as itll evaporate on its own.
da
Aggiungi la tua risposta
Rob sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 60
