Salta al contenuto principale
La Golf MK4 venne introdotta per la prima volta in agosto del 1997, seguita da una versione berlina (VW Bora o, in Nord America, di nuovo VW Jetta) in agosto del 1998 e una nuova Golf Variant (station wagon) a Marzo del 1999.
reset radio golf 2003
Have a Volkswagen Golf 2003 model. How to reset the radio?
Have some errors I believe can be solved with a reset..
The problem is, I use the up-down buttons and switch radio station with nothing happens ..
Antenna is replaced it must be the radio
Questa è una buona domanda?
Punteggio 0
3 Commenti
and always make sure that you have the right reset code.
da
This has been tried!
It does not work. Electricity was off for 30 minutes, and the radio did NOT ask for the radio code.
da
This question was migrated from http://meta.ifixit.com/Answers.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
take of the ground wire from the battery for about two minutes, then put it back on. This should do a reset not only to the radio, but to the whole CAN-Bus system as well.
Punteggio 3
1 Commento:
+flat battery/disconnecting etc has always reset my radio!
da
Aggiungi la tua risposta
Kjetil Pedersen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 55
Tutti i Tempi: 10,692
