Why won’t it turn on?
I got this DVD player at a garage sale it’s never been opened but it won’t turn on. It’s a DR430KU
Questa è una buona domanda?
If it is in a garage i don’t think will turn on. Maybe someone thrown it because it’s faulty. Still you can check some below points:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,030
9 Commenti
We are looking at a device that is likely over 10 years old. Depending on how open you are to poking around inside of the thing you could open it up and check on signs of degraded capacitors. Also is the power supply internal or external? If the power cable includes a large brick in-line then the PSU is external and finding a replacement cord should be your first route.
da Chris Bybee
I think the power supply is internal being that I can not disconnect the cord. I am willing to open it up what should I be looking for?@bybeebuilds
da Dbour
@Dbour Okay yes the PSU is likely internal. If it is getting no power whatsoever I'm guessing we're looking for faulty capacitors or power supply. Generally capacitors used on consumer PCB's have an AVERAGE lifespan of about 6 years under normal operation and I am finding forum posts regarding this model of dvd players from 2010. You're looking for capacitors that are not flushly mounted, leaking fluid, swelled up etc. If you spot none, try and find the power supply in there and try and see if there's anything similar going on inside of there but make sure it is unplugged and still DO NOT MAKE CONTACT WITH THE CAPACITORS with your bare hands, use a plastic tool if you need to make contact with something. I've linked what seems to be a helpful guide in spotting these.
http://www.robotroom.com/Faulty-Capacito...
da Chris Bybee
I don’t see any that could be bad but I’m not entirely sure. Is it worth having it fixed or looked at because I don’t know what I’m doing?@bybeebuilds
da Dbour
@Dbour It really depends on what it would cost to have it looked at and repaired vs just buying a new player and recycling that old one; theres some fairly cheap and probably more advanced stuff out there on the market. However feel free to post some images here including as much of the main board as you can, from different angles.
da Chris Bybee
Mostra altri 4 commenti
