Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
I ruined the antenna connection on the mother board, any suggestions?
While trying to reassemble my iPhone (reconnecting the antenna wire) I damaged the area that holds the antenna wire and now I can't get it to stay on. It's the main antenna so I no longer get phone service. Wifi works fine but no phone. What do I do now? Can I solder it? Any suggestions?
Questa è una buona domanda?
Punteggio -1
2 Commenti
hello i also have this problem sis you fix yours ??
da
I wasn't able to fix it. I don't think I have the skill level to solder it myself this is not an option for me. My iPhone now sits in a drawer.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Indeed the best (and only option in my opinion) is to buy a replacement connector and solder it on. If you have some soldering skills it is not too hard a job.
I'm having difficulties to find one on EBAY. If you are realy desperate to find one please let me know and I might be able to get one for you.
Punteggio 0
Did the connector on the board get damaged or did the part that plugs in get damaged? If the part on the board is damaged and it's not getting a signal, then you would want to find the part and solder it back (being careful not to nick the other components?
Thanks
Punteggio 0
Aggiungi la tua risposta
Jose Codallos sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,933
