Salta al contenuto principale
Repair guides and troubleshooting for the Toshiba Satellite L50-B-2E2 laptop computer.
Boot Loop or What?
**MY LAPTOP IS A L50-C-1FQ BUT I CANNOT FIND IT ON THE DEVICE SEARCH**
Hi there, so I went to power on my laptop and this has happened:
and it does that for as long as it wants.
Background information:
My laptop only powers on when charging and remains at 0% or 1%
I got it on 11 February
1TB hard drive
That is all, thanks.
UPDATE/EDIT: now my laptop does this:
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
That means it’s loading the OS. Could mean anything really. You could try booting into safe mode or whatever. Maybe try disabling secure boot. Could you boot from a usb pendrive and see if you can still see the drive? (maybe clone your disk using clonezilla if you have precious data on it)
Punteggio 0
1 Commento:
Okay, thanks but it has been booting for about 30 minutes I will try those.
da
Switch the ram slots. worked for me.
Punteggio 0
2 Commenti:
Okay thank you for suggesting.
da
Hi so I only have one stick of ram (8gb) and one ram slot it seems, thanks for suggesting though ^v^.
da
has it ever booted up? id recommend starting it in safe mode and see if that works.
Punteggio 0
1 Commento:
Hi, thanks for suggesting I will try those now :>
da
Aggiungi la tua risposta
Uhmm sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 297
