Salta al contenuto principale
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
Is the LM240WU6 SDA1 compatible with the LM240WU2 SL B3?
I need to replace the lcd screen of my apple cinema display 24, the imac 2008 model comes with the same display but slightly different model number, is this display compatible?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Here’s the proper LCD panel for your system 24" Alu LED Cinema Display LCD Panel, Apple P/N’s 661-4822; and the raw panel ID: LM240WU6(SD)(A1)
And here’s the iMac versions:
What you don’t see is the differences in the cable connections (options) which is the code SD and SL. So while the panel is the same you would need to refit the cables over which is not easy! Given the price is the same for what you can get presently I would just get the correct part.
Punteggio 1
Aggiungi la tua risposta
amingomezd sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 391
