Can I switch a 7or8 plus battery to go in a 6 s plus
I wanna trade batteries to my 6s plus and how do I bend back the 6s plus back chassis /body case
Questa è una buona domanda?
Unfortunately none of the iPhone batteries are compatible with each other. Sure you can swap batteries between 2 of the same device, but the connectors are device between each model iPhone, meaning a 7+ or 8+ battery wouldn’t connect, not that it could even fit in the phone in the first place.
As for the bent 6s frame, it should be malleable enough that you can bend it by hand or flatten it against a flat surface, but the device is still fragile and should be treated carefully.
It's a real shame as the 6/7/8 are all practically the same device but all the connectors are different purely so Apple can retail more expensive replacement parts each year instead of allowing someone to use an older part
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 38
