Salta al contenuto principale
Numero modello A1707. Rilasciato a giugno 2017, questo MacBook Pro adotta processori Kaby Lake fino a Intel Core i7 quad core da 2,8 GHz con Turbo boost fino a 3,8 GHz.
327 Domande Visualizza tutte
Failed Battery Replacement. 2017 MBP CPU repair store cant fix either!
My 2017 15” Touchbar Macbook Pro was in good working order, battery life was meh, so I bought the battery kit, replaced it.
However upon what I thought was a successful replacement, the computer failed to power on, or even charge. I took it to a computer store and they attempted to replace a flex cable they said was under the main logic board that was torn, which did not fix the issue either.
they have since given up and only charged me a diagnostic fee.
any suggestions?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
At this point you’ll need to go to an Apple Store to have it looked at.
Punteggio 0
in the tear down it says something about making sure you don't touch something that would fry your logic board..
Most likely you missed a cable or one of the cables is not on securely.... If I was you unless you have 500..00 I would spend a weekend day and tear it down slowly and make sure you did not miss a step
Punteggio 0
Aggiungi la tua risposta
dieselraver sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 222
