Salta al contenuto principale
A1708 / EMC 3164 — Lanciato a giugno 2017, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED.
NDC001 error code after screen change
Hello, I bought a 2017 MacBook Pro A1708 without Touch Bar with a broken screen. After changing the screen and doing a diagnostic I have the error code NCD001 which means the camera is not connected and therefore not working (FaceTime and photobooth). After performing the following operations: SMC, NVRAM, it still does not work. Has anyone had the same problem as me and if there is a solution I'm in! Thank you
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hey did you ever get it figured out?
Punteggio 0
1 Commento:
No, I didn't found the solution
da
i’ve same problem too!
Punteggio 0
1 Commento:
wonder if anyone managed to figure it out. Im thinking it might be the flex cable that was damaged?
da
Aggiungi la tua risposta
Noémie THOMASSET sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 535
