Salta al contenuto principale
Lanciato il 21 settembre 2018. Modelli A2097, A2098. Disponibile come GSM o CDMA / eSIM o nanoSIM / 64, 256 o 512 GB /Argento, Oro o Grigio Siderale. (Si legge "iPhone 10 S").
398 Domande Visualizza tutte
iPhone XS restarts randomly and lags
Hello, so my iPhone after upgrading to iOS 14 side buttons are slow to response when pushing wake button screen turns on like 5s after, same with volume. Randomly restarts, like 5 times a day and its pretty annoying. But when i force restart it goes back to normal and works perfectly fine, but after a while it goes back to slow responses and random restarts after restart it works good, but slow responses comes back and it restarts by itself or I have to force restart it. So any solutions? Or maybe do u know any causes of this problem? Before this problems screen and battery was changed, but phone was working good in iOS 13. I didn’t try to restore, but I tried to update through iTunes, but i got an error message. But I can update from phone with any problems, but restart and slow response problem persists. So I checked crash log and found “Problem connecting cpu and peripherals”
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
iPhone randomly or keeping restarting could be iOS or software-related glitches, to fix it, you could try,
  1. Force restart iPhone.
  2. Restore iPhone via iTunes (data loss).
  3. Fix iPhone restarting by Joyoshare Ultfix, etc ios system recovery tools.
Punteggio 1
Check if there is and dust and debris in the Phones Volume Buttons and sleep button after all there is a bit of space in between the Buttons and the Plate, if there is Then unscrew and use canned air to clean it out.
Punteggio 0
8 Commenti:
Thanks for the reply. I don't think its the problem, because when I restart my phone it goes back to normal.
da
Did you try resetting it
da
No, u think it would help? And in panic file i found that there are some errors like "Unexpected SOC(sysem) watchdog reset occured" "no succsessful checkings from com.apple.thermalmonitord since wake" and something with cpu panic
da
Did this Happen maybe after downloading something?
da
I think after ios 14 update, but before update I felt freeze when typing last digit off the password.
da
Mostra altri 3 commenti
Aggiungi la tua risposta
Orestas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 956
