Salta al contenuto principale
Rilasciato a luglio 2018, il MacBook Pro da 15", modello A1989, adotta uno schermo retroilluminato a LED da 15,4" con tecnologia True tone, Touch ID e processore fino a esa-core Intel Core i9.
204 Domande Visualizza tutte
What happened to my Touch ID button?
I took apart my MacBook Pro to replace the thermal paste today and when I put it back together, everything worked fine… except for the Touch ID sensor and its button.
I can’t use Touch ID and pushing the button does absolutely nothing whether the thing is on or off. Is there a connector inside the machine that I forgot to reattach which makes the button work, or could something have been irreversibly damaged?
Nothing else seems to be amiss and I can deal with not having a power button in regular use, but if the computer stalls I want to have that failsafe.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
We can’t see your computer or what you did to it, so we wouldn’t know.
You have to check missing connectors yourself, if all connectors are secure, chances are you tore the cable.
Punteggio 2
Aggiungi la tua risposta
Jacob Kowanetz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 51
