Salta al contenuto principale
Modello A1989, EMC 3358. Aggiornamento del modello esistente, con nuove opzioni per il processore e un cambiamento nei materiali della tastiera. Disponibile nei colori Argento e Grigio siderale. Rilasciato nel maggio 2019.
134 Domande Visualizza tutte
How to make external display active with dead internal display
I got in an a liquid damaged MBP. The internal display is not working. An external display does work but all it’s showing is the users desktop image. I need to make it the active screen so I can get into Terminal to turn off the auto-boot. I’ve forgotten how to do it. Also any hints on what to look for on the liquid damage would help. Thanks. @danj
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@mayer - Did you close the lid?
Using an external keyboard and mouse you should gain access to the primary display window after you close the lid.
Punteggio 2
3 Commenti:
@danj That works, Thanks. Any idea of what to look for as to the failure of the internal display?
da
@mayer - Likely a blown T-CON board. A common issue in this series as they run too hot!
da
The kid woke up and realized it was covered under his AppleCare after I cleaned it. Did do a Time Machine backup and restore his data onto a new MBP.
da
Aggiungi la tua risposta
mayer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 105
