Salta al contenuto principale
La versione rinnovata, a lungo attesa, del popolare MacBook Air, con processori Intel Core i5, un Retina Display aggiornato e numerosi altri cambiamenti e aggiornamenti. Rilasciato il 7 novembre 2018.
149 Domande Visualizza tutte
Trackpad and keyboard not working after trackpad replacement?
Hello, I recently performed a trackpad replacement, due to water damage. Prior to the replacement my keyboard and everything else had been functioning on my laptop, but after the trackpad replacement, neither the keyboard nor trackpad are working. I tried checking all of my connections and can’t seem to find the problem. I hope to at least get the keyboard back to normal. Any advice is appreciated!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Did you connect the flex cable s
Punteggio 0
1 Commento:
I believe so. I had bought the flex cable and trackpad and connected them together as well as connected the flex cable to it's two other points.
I don't know what the connection beneath the logic board is to exactly. Does that have something to do with the keyboard?
da
Review this guide MacBook Air 13” Retina Display Late 2018 Trackpad Replacement
The trackpad and keyboard share the same cable. One connection on the logic board and then it splits to two paths one to the keyboard and the second to the trackpad. Make sure all three cable connections are secure.
MacBook Air 13" (Late 2018-Mid 2019) Trackpad Cable
Immagine MacBook Air 13" (Late 2018-Mid 2019) Trackpad Cable
Prodotto
$18.99
Punteggio 0
1 Commento:
Thank you! This guide is great. Unfortunately, it still isn't working. Maybe the flex cable isn't working or I damaged a port or something :/ I'm ordering another flex cable in hopes that that will work.
da
Aggiungi la tua risposta
stephinatorallen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 120
