Salta al contenuto principale
Un piccolo aggiornamento del MacBook Air di fine 2019, con lo stesso numero di modello (A1932) e numero EMC (3184). Questo modello ha uno schermo True Tone e una batteria leggermente revisionata.
86 Domande Visualizza tutte
How do I fix my space bar key?
I removed my space bar key to get paint off of the key cap and I tore the silicone membrane in the newer models, I’m not sure if I need to replace the silicone membrane and if so, how to. Answers would be greatly appreciated if anyone knows!
Questa è una buona domanda?
Punteggio 3
1 Commento
Is your space bar working now?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
I’m afraid the keyboard is part of the upper case of the MacBook, meaning that you’ll need to get a complete upper case in order for you to fix the keyboard. You can read more in the upper case replacement guide. But I’m not sure if the membrane is that critical to the operation of the keyboard. Maybe try first if simply re-assembling the keyboard makes it work again, that way you don’t need to buy an expensive upper case.
Punteggio 1
1 Commento:
Thank You so much @bramdriesen! I will try to repair it and see if it works!
da
Aggiungi la tua risposta
Lightmers sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 22
Tutti i Tempi: 743
