What is the correct part for the Charging Port?
Can anyone link me to eBay or Amazon with the correct female Micro USB B-Type solder socket?
Questa è una buona domanda?
Punteggio
0
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 39
I’m going to try this one and report back: https://www.ebay.com/itm/174405411042
da Mike O.
@sublimesed Looks about right. Looks like a micro-usb b port: https://www.cablestogo.com/learning/conn...
da DunCanP
Thanks, wish me luck!
da Mike O.
@sublimesed No need, you got this. I just wanted to confirm your findings in case you we second guessing. Be aware, you will need to use a solder wick to pull solder off the "holding pins" before you can take the connector off. Make sure you tin the bottom of the new connector (don't need a lot) and use a magnifing glass. Just a few pointer in case you haven't done this before.
da DunCanP
@dunc much appreciated!
da Mike O.
