Salta al contenuto principale
Guides and repair information for the LG Exalt VN220. The LG Exalt VN220 (also called the LG Exalt or Exalt LTE) is a flip phone released in 2018.
phone has broken in half?
so my duct/gorilla tape did not hold for this ‘final fall’:0\. the top/screen half has broken away, the little cable(?) connection has snapped. was to use phone as storage until i transfer contacts/pics to new device or pc at a later time. can i just have to get another(used!) lg vn220 and move the *sim* over to it?? thank you in advance for any guidence:o|…. (tues.-jan.26) so here’s a photo of ‘the situation’. can the ribbon cable be spliced or should it be replaced.
ty:)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
The best option would be if you can get another center brace, either by getting someone's old phone that he thinks it's useless because it's dead, or you can buy it online at GLOBAL DIRECT PARTS, or on eBay, etc., the difference is going to be that buying it online it's going to be quite difficult figuring it out if you're not experienced in electricals, vs. getting it used it's %95 done, you just have to assemble the top and the bottom side to it.
Hope it's still relevant by now!!
Punteggio 0
Yes either a new Phone and swap bottom boards to pull the info off. or look on ebay to buy parts to fix on your own.
Punteggio 0
Aggiungi la tua risposta
mkbatt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 489
