Joy-con stuck on nintendo switch and broken.
My Joy-con is broken and it is stuck on my Nintendo Switch… Is there any way to remove the remaining part of my Joy-con from the Switch?
Questa è una buona domanda?
I’ve figured it out by myself, but in case if anyone’s having the same problem as me, I’m posting this by my self.
You can try pushing the red part of the image all the way, and it will probably detach.
Thank you. This has been the only useful thing I have found for the same issue. All fixed now!
i tried it didn't work for me, is there any other ways
edit: i tried again a few more times and the remaining piece finally got out! thanks
I had this same problem so now m parents are gonna kill me but I saved my switch. :/
thank you so freaking much!!
THANK YOU SO MUCH!!! However… is there any way i can get the orange straps back into the joy con?? Or would i have to contact support for this… i have no expire with unscrewing joy cons and stuff D:
Dose this work for the right joy con as well? I have the same issue rn. Thank you in advance
it works on both so yes
Bro, literally happened today. BLESS YOU mother F'er. Forever thankful 🙏
i don’t have a red thing 😬😬 my parents r going to kill me…
Oreo, when Yoon said "the red thing", he was talking about the part of the joycon still stuck on the console that he'd *circled in red* in his picture. Find that same spot on your joycon rail and press it and it should slide out. When your joycon is intact, that's the part the release button moves against when you press it.
ohhh my bad i the picture it looked like it was red 🫣 but i figured it out but now i gotta figure out how to get the controller back on
What red thing I don't see it
Thank you for this. Slid right out! Life saver! Lol
My switch fell and now the black controller broke and now there is yellow wires
You beautiful life saver you
Ultime 24 Ore: 11
Ultimi 7 Giorni: 82
Ultimi 30 Giorni: 397
Tutti i Tempi: 17,553
8 Commenti
My long distance boyfriend had this issue for at least 2 days, and he was a bit scared on how to fix it. This helped get those broken pieces off right away! Thank you, now we know just in case this happens again, since we do enjoy playing Minecraft every day
da Chick Drumstick
Ohh push from the back of the console down not in, got it now
da wade-p2
Do you push it into the switch or away from it?
da lilchocobro lilbro
Which way do you push it?
This happened to me, the only thing I'm struggling with is putting the top back on...
da Daisy
Mostra altri 3 commenti
