Salta al contenuto principale
Lanciato il 20 settembre, il telefono di punta di Apple per il 2019 ha display OLED da 5,8", tripla fotocamera posteriore e autonomia molto migliorata. È il successore dell'iPhone XS.
150 Domande Visualizza tutte
Why are my apps see through
Hello, lately my iPhone has been rebooting itself out of nowhere. I could be on FaceTime then all of a sudden I see a black screen with the loading circle thing, the call does not end or nothing but when it turns back on my apps are see through. I can still tap them but they seem to be disappearing. Also if I am on a app such as TikTok and the problem occurs, it is not like how it is if I was on a call meaning I still am on the call while rebooting… it will take me out the app and close down all the apps that were previously open.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
I would try to do the basic procedures first. You could reset the phone or even put it in DFU mode (please look on youtube) to make a clean restore. You will lose your data but if that’s a software failure then it will be gone. If the problem stays, then this might be a very serious hardware issue…
Punteggio 0
Sometimes the problem is that your phone loops because it is tied to a certain date when the next operating system update was scheduled. As a result, it repeats the same action, constantly rebooting. All you need to do is change the date, and maybe the problem will be solved. To do this, go to "Settings," then to "Basic," then scroll down the list and click on "Date and time." Here you change the date, for example, to a month ago, and check the functionality of your iPhone. You can find out about new updates to Apple technology in the news at zumroad.com. I hope you can solve this issue.
Punteggio 0
Aggiungi la tua risposta
Shenaya alexandra sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 534
