internal drive (dvd-cd drive) spits out cd.
I'll load a cd for a new app and it will spin for about ten secs. and then ejects. Doesn't matter if it's music or a new operating system.
Questa è una buona domanda?
Hi! It's likely that the drive has gotten touchy and needs to be replaced. However, there are some things you can try: Make sure your CDs are clean and free of smudges. You can use Windex and a soft cloth to clean them. Also, make sure to try many different discs, i.e. CDs, and DVDs, in order to insure that it's not just a specific set of media, or a certain type of disc that is causing the issue. You can also blow the drive out with canned air, and you can also try one of the many commercial laser/lense cleaners, which may help if the drive is just dirty. If none of this helps, though, then likely the drive simply needs to be replaced. Unfortunately it's a common occurrence. If you can post the specific model number of your machine, I will post a link to the appropriate iFixit part, or you can walk through the machine locator wizard. http://www.ifixit.com/Info/ID-your-Mac
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,733
1 Commento
If one of these answers fixed your problem please hit the "accept" in list that has "History Edit Flag Accept Comment" located to the upper right of your question so we can remove it from the unanswered list. Thanks so much.
da mayer
