Salta al contenuto principale
Lanciato nel giugno 2009 / processore Core 2 Duo da 2,66, 2,8 o 3,06 GHz
300 Domande Visualizza tutte
How to disconnect the keyboard cable from logic board?
Hi, I have a macbook pro which has some spill damage and couple of keys damaged by kids along with the glass of display. It has some key stuck on it too (I dont know which ones exactly as i cant go pass the log on screen), It boots but I cant put it in safe mode or put the password as the keys I need to press is broken too. At this moment i just want to see the extent of the damage as see if it is worth me fixing it or not. I just want to connect it with a USB keyboard and see how many components are not working. To do that I need to disable the Macbook Pro keyboard.
I want to know If it is safe to turn on the Macbook without the keyboard cable attached? it is then how can i do it.
Any help will be appreciated.
Regards
Syed
Questa è una buona domanda?
Punteggio -1
1 Commento
I have the Flex cable removed. but I think the power button is connected to keyboard as well... any chance of jump starting the macbook without the flex cable attached?
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Plug in an external keyboard and restart, it should over ride the internal board and let you test your unit.
Punteggio 3
2 Commenti:
I tried but it doesnt over rides, both keyboard works same time and as the internal keyboard have some keys pressed permanently, I cant get into safe mode or anything.
da
Frankly at this point, it might be better to take it to a pro that has spare parts. You need to determine if the problem is isolated to just the keyboard which involves replacing the upper case, if it goes deeper the cost of repair may be prohibitive.
da
mayer is ryt to check to over ride the internal keyboard . otherwise here is the link to remove the internal keyboard flex from logic board see the step 18 :
MacBook Pro 15" Unibody Mid 2009 Logic Board Replacement
Punteggio 1
4 Commenti:
da
I did and guess what? $800 for upper case and $1500 for display... cheaper to buy a new one.... such a waste...
da
your email address ? syed
da
That's just way out of line on prices. I'd check with some of the professionals on this site by clicking on their icons and looking at their web sites and emails. The guys in sepia work for iFixit and generally just write manuals, so skip over them.
da
Between the RAM and the speaker cable connector( the speaker that sits under the DVD drive) there are two contact points where it says PWR BTN. Connect these two points and it will do the same as pressing the external power button. If you have a external keyboard connected it means you have to open the bottom lid every time you wanna turn it on :)
Punteggio 0
Aggiungi la tua risposta
Syed sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 12,074
