Salta al contenuto principale
Impara a conoscere le competenze di cui potresti aver bisogno per lavorare sul tuo dispositivo.
Which iFixit Tool-set? What alternative?
Subject: Which iFixit Tool-set? What alternative?
I recently tried to replace my Mac mini 2014 HDD to an SSD…. the problem was that I did not have a Torx 5 bit…. I thought I would invest in a somewhat comprehensive set like the Pro Tech Toolkit or Manta kit…. I guess one downside is that the bit swap concept is more bulky and more cumbersome than dedicated tools for each bit… I think I like the case for the Pro Tech better…. I think Manta as some longer bits that are useful….. Also, I wonder if there is a reputable alternative to the iFixit Chinese tools…. any thoughts?
Oh, I just broke the screen on my iPhone 6s….. so I might need some tools for that.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
Here’s a kit to use for most repairs including the iPhone 6
Pro Tech Toolkit
https://amzn.to/37ow346
Immagine The original electronics toolkit: Designed for computer, smartphone, tablet, and gaming repair, backed by thousands of free instructions.
Prodotto
Pro Tech Toolkit
$74.95
Punteggio 4
Each guide offers a listing of the needed tools for the given task. Review them to help understand what you’ll need.
Someone who is a weekend fixer will likely find the Pro Tech Toolkit is a good choice as it will cover a good 90% of what you’ll need for small device repairs.
A person who focuses on fixing MacBook system will often get discreet handle drivers as they are constantly using the same tool over and over again.
I personally have both the iFixit Pro Tech Toolkit so when I travel I have what I need. When I’m home I often use my fixed handle drivers similar to the iFixit Marlin Screwdriver Set - 15 Precision Screwdrivers
Your use case can be different from me! So you need to figure it out what works for you.
Prodotto
Pro Tech Toolkit
$74.95
Immagine Phillips, Torx, Torx Security, iPhone Standoff, Tri-point, Pentalobe, and Flathead screwdrivers packed inside a fabric tool roll for compact storage.
Prodotto
$54.99
Punteggio 3
Aggiungi la tua risposta
Mac Fun sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 89
Tutti i Tempi: 4,654
