Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
1185 Domande Visualizza tutte
Keyboard logic board bracket replacement
Hello can anyone tell me if i can replace the bracket that made pressure to the keyboard flex? yesterday trying to align the flex the bracket was broken. here is a photo.
Questa è una buona domanda?
Punteggio 0
2 Commenti
@itscrocs15 what exact model is your MBP?
da
2015 AND THE FLAP is broken.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Here’s the needed connector part Keyboard Connector (30-pin). Carefully pop off the compression bar and insert it back in on yours. As long as the base is not damaged that should do it!
If not then you’ll need to remove the old connector and replace it fully. This is not a DIY job, you’ll need to find someone with the proper tools and skills to put on the new connector.
Punteggio 0
Risposta Più Utile
@itscrocs15 your picture is a bit dark and hard to see. If the flap is broken and cannot be reinserted you will have to replace the connector. That will require some good skills and tools and I would consider sending it out for repair.
Punteggio 1
Aggiungi la tua risposta
Abdiel Crocamo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 83
